Error Messages
Why do I get the error: exit code -1073741510 (0xc000013a) (On Windows Vista)?
The message exit code -1073741510 (0xc000013a) means that when you log off of Windows the application gets terminated quite abruptly. Vista can shut down very quickly and not allow BOINC enough time to stop properly. This problem was corrected in the 5.10.45 version of BOINC. Please ensure that you are running the latest recommended version of the World Community Grid software.
To determine what version you are currently running on your computer, right click on the World Community Grid, or BOINC, icon in the bottom right corner of your display (by the date and time). Click on “About World Community Grid – BOINC Client” or “About BOINC” and the current version of the software will be displayed.
You may check if you have the latest supported version of the World Community Grid software by visiting this page: https://www.worldcommunitygrid.org/ms/viewDownloadAgain.do . The version number is displayed below the name of the agent for each operating system. If this number is the same as the version number that you have installed then you have the latest supported version.
